Xkr100 to xjr100 engine swsp
Old Dec 2, 2022 | 01:50 PM
DrewH777's Avatar
Default Xkr100 to xjr100 engine swsp
Xkr100 to xjr100 engine swap,
I have a xjr100 needing an engine and i have available a motor from a damaged xkr100, is this a straight swap.both 2002. Both usa spec.
Old Dec 2, 2022 | 02:05 PM
Addicted2boost's Avatar
Yes, no modifications needed on the replacement engine. I would replace the rear main oil seal and cap seal 2” above it. I would also replace the timing cover and valve cover gaskets while it’s all out and easy. The only other thing I’d do is flush out the engine oil cooler to be on the safe side.
jackra_1
Jan 20, 2020 11:05 AM
stacey honn
Dec 8, 2019 08:48 AM
tedwone
Jul 1, 2017 01:35 PM
reichstall
Mar 29, 2016 09:03 AM
wotcham8
Jun 5, 2013 03:24 PM
