Yet More Heater Problems - 2001 VDP
Old Jan 23, 2012 | 09:47 PM
plums's Avatar
Nope. That would be a JTIS thing.
Old Jan 24, 2012 | 01:16 AM
yeldogt's Avatar
To clean ACC sensors I normally vacuumed the grill off -- with a brush attached to my vacuum and then use the hose w/o the brush to clean out the sensors - I keep my finger in the way so that the full force of my vacuum is not sucking on the sensor and tube to the climate control. Normally what happens is dust clogs the intake and slows the flow into the sensor.
I believe the Jaguar AAC works in the conventional way -- putting the system on "HI" will tell the ACC system to move to maximum heat - so if you are not getting heat on "HI" then it is not the temperature controls.
I would place the ACC on "HI" and see if all the hoses get hot:
Have you ever had any water pump issues or strange coolant?
toronadomike
Jan 22, 2026 10:13 PM
Bcrary3
Sep 12, 2021 05:41 AM
Dicque
Sep 19, 2015 12:53 PM
gregster41
Sep 6, 2015 06:51 PM
Dicque
Sep 4, 2015 12:50 PM
