ZF5HP24 Pressure regulator Valve
Old Feb 13, 2018 | 12:12 AM
cliveb's Avatar
Default ZF5HP24 Pressure regulator Valve
Hello everyone, as a new '99 x308 VDP owner, I been reading about the replacement of the pressure regulator valve to an upgraded version to avoid "A" drum failure. Currently my 308 has 74k and drives beautifully. It's currently having the timing chain tensioner upgrade, and I read on this forum that the pressure regulator valve should be changed to avoid a transmission disaster. My question is, can this be done without removing the transmission, and if so, is it a job a novice could tackle? Also what is the TransGo kit, and would it contain the upgraded pressure regulator valve.
thanks
Clive
Old Feb 13, 2018 | 02:12 AM
Stu 1986's Avatar
The TransGo kit is the upgraded valve, it's made in the USA and it's beautifully machined. It is fitted without removing the transmission from the car, however you will have to drain the fluid and drop the valve body. I had mine done by a professional so I was covered in the event of future issues, but if you have the space, kit and time you could try it yourself.
It's worth getting it done and the fluid replaced at the same time, your fluid will no doubt be well overdue being changed at this point in it's life.
Old Feb 13, 2018 | 02:26 AM
Daim's Avatar
Yep. The valve body only needs to be removed, which isn't a hard job, and that valve is just replaced.
Old Feb 13, 2018 | 07:01 AM
A.J.P's Avatar
Hi cliveb,
This should help,
https://www.jaguarforums.com/forum/x...pgrade-179012/
Good luck,
Andy
mrplow58
Aug 24, 2016 07:48 PM
EZDriver
Sep 29, 2014 04:24 PM
car5car
May 20, 2014 10:15 AM
Skid Mark
Feb 5, 2013 10:22 PM
NorCalDiesel
Jun 22, 2009 06:49 PM
