XJ40 ( XJ81 ) 1986 - 1994
1988 Jaguar XJ6 Belt search
Old May 15, 2017 | 11:45 AM
Jaguar Dre's Avatar
88 XJ6
Question 1988 Jaguar XJ6 Belt search
Hey Jaguar lovers.... I have a question. What is the name of the very small belt connecting to the fan belt on my jag? I have changed all belts except for this belt and it causes my car to squeak for about 2 mins when i first start my car up. I think the size is a 13x1150 but i cant find this belt anywhere. I tried different part stores and they cant locate or identify the exact belt and size i need. I think its the drive accessory belt that connects to the fan belt but im not sure. It is an original stock belt that is still on my jaguar but its going bad. It has jaguar logos printed on the outer part of the belt. If anyone has the answer to this problem i would greatly appreciate it if the knowledge of what the belt is exactly called and where can i find another one to purchase is shared with me. I need replies ASAP thanks Jag lovers and have a good day!
Old May 15, 2017 | 12:40 PM
I've moved your question from US Lower Atlantic Region to XJ40 forum. This is the place to post technical questions about your model.
Old May 15, 2017 | 02:05 PM
Don B's Avatar
Hi Jaguar Dre,
I believe your 3.6L engine has a main belt that drives the alternator and water pump from the crankshaft (1); a second shorter belt that drives the air conditioning compressor from the crankshaft (2); and a third, even shorter belt, that drives the secondary air injection air pump from the water pump pulley (3).
Here's the diagram from jaguarclassicparts.com:
Cheers,
Don
Old May 16, 2017 | 12:36 AM
Lawrence's Avatar
I just bought all three belts from Rockauto, very reasonable and top brands
Old May 18, 2017 | 12:45 AM
Jaguar Dre's Avatar
88 XJ6
Originally Posted by Don B
Hi Jaguar Dre,
I believe your 3.6L engine has a main belt that drives the alternator and water pump from the crankshaft; a second shorter belt that drives the air conditioning compressor from the crankshaft; and a third, even shorter belt, that drives the secondary air injection air pump from the water pump pulley.
Cheers,
Don
Thanks i found it and ordered it off of parts geek.com and found the exact match. Now thats love mannn!
Ingo85
Oct 12, 2016 01:35 PM
itchyback
Oct 10, 2016 07:56 AM
Audio/Visual Electronics
Jan 24, 2010 09:27 AM
Feb 28, 2006 03:53 PM
