XJ40 ( XJ81 ) 1986 - 1994
1988 XJ6’s door question
Old Apr 10, 2021 | 01:11 AM
Putter03?'s Avatar
Default 1988 XJ6’s door question
Newbie here, I have two 1988 XJ6’s with the usual door handle problems. My question is, can brake cleaner be used to clean the door latch mechanism, then it’s white lithium grease to lube? One has 1 working door, the other has one going bad. Newer one has 86,000 miles on it from California. Thanks ahead for your thoughts. 1988 Putter
Old Apr 10, 2021 | 07:29 AM
jerry_hoback's Avatar
I would not use brake clean with the latch in the car. On the bench, and with whatever rubber removed , yes I would. If you are concerned about the plastic parts give a tiny squirt and see what happens first. Your next problem would be getting grease back into all the little crannies.
Old Apr 10, 2021 | 06:00 PM
Naki's Avatar
Brake cleaner is to remove grease/ oil.
You want to add lubrication, not take it away.
Just use the spray white grease. Work the system to move it around. Adjust the latch rod to the handle as required to make it function smoothly.
Old Apr 11, 2021 | 01:04 AM
Putter03?'s Avatar
Default Putter03? Here
Thanks for your help, next question, where do you fill the SLS system at. And thanks for the help again. Putter
Old Apr 11, 2021 | 08:24 AM
motorcarman's Avatar
The Jaguar Publication S73 has all the info you need for the Hydraulic System.
File is 4.2 mb which is too large to post here I believe.
Old Apr 12, 2021 | 07:44 PM
Don B's Avatar
You can download the publication Bob mentioned at the link below, courtesy of our member Gus and Bob, who probably supplied the file to Gus!
Jaguar XJ40 Power Hydraulic System S-73
Cheers,
Don
JensenHealey
XJ40 ( XJ81 )
Oct 13, 2019 06:26 AM
philhef
Dec 11, 2012 06:15 AM
pingj
Aug 24, 2012 04:40 AM
totalimmortal363
Jul 20, 2012 09:56 PM
FloridaXJR
Jul 20, 2011 09:33 AM
