XJ40 ( XJ81 ) 1986 - 1994
1989 xj40 Low Vacuum
Old Mar 16, 2014 | 02:16 AM
Garry E Vincent's Avatar
Default 1989 xj40 Low Vacuum
Hi Again,
Following up on my last post with trying to solve the low engine Vacuum.
I removed the front spoiler to view the charcoal canister tracing all hoses . I found the purge valve had been disconnected from the connecting hose. The electric connection was still in place.
I removed and inspected all components and testing the purge valve I found it was faulty.
Having trouble locating another I carefully dismantled the one I had to find it was caked with dirt/dust/grime.
I rebuilt and moulded back together. Tested ok and reinstalled.
checked the jaguar manual for a schematic to make sure the installation was as it should have been.
Unfortunately this had no affect on my current Vacuum readings. I will keep looking.
Could some one assist with another issue.
  • FAULT 23. The book reads Fuel supply as the description with in the Function column it reads " look for poor feed back control in rich direction" Sorry but I don't understand this.
  • The other one is the elimination on the dash indicating a failed fuse in fuse location No 2. I checked all fuses and all ok. I removed the side cover making sure that there was no others fuses hidden away. ( as this vehicle was pre owned ).
Thanks again
Garry Vincent
1989 xj40 Sovereign.
Bcrary3
Feb 21, 2023 04:29 AM
vinny jones
Oct 5, 2015 07:20 AM
Regular rick
Sep 24, 2015 08:35 PM
alextoevs
Sep 20, 2015 05:21 PM
1100me
Sep 7, 2015 06:26 AM
