XJ40 ( XJ81 ) 1986 - 1994
1990 Sovereign (XJ40) Handbrake
Old Sep 26, 2008 | 08:20 PM
tomwerry's Avatar
Default 1990 Sovereign (XJ40) Handbrake
Rats - I lied. Everything else is not working okay!
For quite a long time when I got this car, the PO had been driving it with the handbrake stuck partially on, and I unknowingly did the same for a short while before I went overseas and put the vehicle in storage.
Now on thoroughly going over everything I found that the thumb-button to release the handbrake does not in fact do so, and I can only release it completely by prying out the coggy thingee with a BFS to lower the handle far enough to actually release the drums completely.
This mechanism is stuck down beside the seat, and a bit hard to get at to see what's wrong. I can see an aircraft style crowned nut holding the handle on to a shaft, and below that there are 2(?) nuts fastening the mechanism below to the frame, I guess.
There are also a couple of screws and some other flat metal bits I can see, as well as the pawl I pried up to release the thing.
Is there a right way (and a wrong way?) to dismantle the brake handle to fix whatever is wrong with the release mechanism?
Thanks for any insight.
- Tom
Old Oct 2, 2008 | 08:59 AM
tomwerry's Avatar
Default RE: 1990 Sovereign (XJ40) Handbrake
Sorted it all out - thanks to all responders forthe help.
sadepol01
16
Nov 22, 2024 05:05 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Dave1109971
Dec 15, 2015 06:16 PM
XJRick
Sep 28, 2015 02:12 AM
