XJ40 ( XJ81 ) 1986 - 1994
1991 XJ6: AC / Heat problem
Old Feb 3, 2009 | 03:14 PM
kramxel13's Avatar
Default 1991 XJ6: AC / Heat problem
When I turn the climate control on high, it only blows full speed out of the vents below the windshield. (the one for defogging) Very little air comes out of the forward facing and rear vents.
Does anyone know a possible cause of this?
Old Feb 3, 2009 | 03:28 PM
JagtechOhio's Avatar
Default Defroster ducts staying open
Greetings,
Two controls open the defroster ducts. One is "defrost", which releases vacuum to the ducts and allows them to open, while also cycling the system over to heat at the screen.
The other is a pushbutton on the panel which has a logo for the windshield on it, I think it also says "air" in the picture, and that opens the defroster vents to provide air to the screen at whatever temperature the system is currently maintaining.
So if set properly, here's why they are open when you want them closed:
Low vacuum in the system, lots of places to look;
Defroster flaps broken, the hinges fail and the airflow is not blocked even though the vacuum actuators are intact and still working;
The three screws that hold each defroster flap up to the duct inside the dash have come loose, and you can remove the black outlet grille, hold them back up in position and resecure them. This happens frequently, and is an easy fix. Replacing the defroster ducts is remove/ refit facia (dash board). You will not be amused.
Old Feb 3, 2009 | 04:29 PM
kramxel13's Avatar
Thanks man, I'll try it tomorrow and let you know.
Old Feb 8, 2009 | 02:36 PM
kramxel13's Avatar
Ok, well it turns out that wasn't the problem. The defogger vents open and close correctly.
There is just a really weak stream of air that comes out of the vents, hot or cold. The High, Medium, Low gives variable speeds, but it is a really weak flow of air on all of them. All fuses are good. Any known problems for a weak blower?
Old Feb 8, 2009 | 02:59 PM
Yep, there are two blowers in your car and one of them is not working. An individual fuse for each is in either side fusebox, when you pull the fuses wou will be able tell which motor has failed.
Old Feb 8, 2009 | 03:20 PM
kramxel13's Avatar
Pulled the fuse LH AC Fan / LH Heater, and it continued to blow at the same pace. I'm guessing it's not a easy fix?
Old Feb 8, 2009 | 03:24 PM
I guess the good news is that it's the left, the right is a bit more difficult to remove and refit. Go back through the threads and look for ArmyJag posts, all of the pertinent onfo is there and it was within the last few weeks. Let me know if you want to buy a good used blower maotor assy.
Did you get the intake runner on OK?
Old Feb 8, 2009 | 03:32 PM
kramxel13's Avatar
Well I patched the old runner with a piece of plastic and some jb weld, haven't had time to put the new one on yet.
And what price can you get me on a blower motor?
Old Feb 8, 2009 | 03:45 PM
Good used blower motor assemblies are worth $100 to me: I still own four XJ40's and service a bunch, so I don't sell high demand components at dirt cheap prices. I'll make sure I have a good LH to fit your '91 if you are interested, PM me.
Old Feb 8, 2009 | 08:09 PM
kramxel13's Avatar
I sent you a PM.
Old Mar 11, 2009 | 01:38 PM
kramxel13's Avatar
Just an update, finally got the thing installed, everything works good! Thanks man!
Old Mar 11, 2009 | 01:53 PM
Awesome, thanks for the note. That blower motor was so nice, I didn't want to put it in the box!
Let me know if you are still waiting on a hood, I'm talking to a guy in D.C. about some sheet metal right now. Could be a road trip coming together. Thanks again for your business!
Old Mar 11, 2009 | 08:35 PM
kramxel13's Avatar
We're going to pick up some body filler on the weekend, trying to fix it ourselves first. What was the price on that hood again?
Old Mar 11, 2009 | 08:44 PM
Thanks for the inquiry, I'll PM you.
H20boy
Dec 24, 2024 03:23 PM
jdzubas
Oct 4, 2015 09:14 AM
obwoodie
Sep 3, 2015 07:45 PM
Bcrary3
Sep 3, 2015 03:48 PM
laserguy
Sep 3, 2015 02:02 PM
