XJ40 ( XJ81 ) 1986 - 1994
1992 XJ40 Needle Bearing
Old Feb 7, 2024 | 12:26 AM
Herschel's Avatar
Default 1992 XJ40 Needle Bearing
I am looking for the Needle Bearing for my steering rack. This is the Combined Needle Bearing. It says "Nadella 10687". Where can I buy this?
Old Feb 9, 2024 | 05:40 PM
jerry_hoback's Avatar
i would try entering that name and number in a search engine and see what yiou get.
Old Feb 12, 2024 | 12:00 AM
Herschel's Avatar
Hi
jerry_hoback, tried every possible means to search and locate but no luck. I checked with Martin Robey and they said Jaguar never listed this bearing as a spare part. As a last resort, I came here.
Old Feb 12, 2024 | 01:35 AM
newyankee's Avatar
"Nadella" quite likely is nothing more than the abbreviation for "Nadellager" which ist german for needle bearing. The number then might be specific to the rack manufacturer. I would measure the bearing and try to source something generic.
On a 1992 I assume this is a ZF rack.
Old Feb 13, 2024 | 10:48 PM
xalty's Avatar
https://www.jaguarforums.com/forum/a...0-zf-servo.pdf
they give you the dimensions
Old Feb 13, 2024 | 10:58 PM
farm-jag's Avatar
AFAIK, if you get with Timkin, you can get pretty much any kind of bearing with the proper dimensions. That, or a salvage yard/Ebay, though not sure the likelihood of finding just the bearing on the latter.
Old Feb 21, 2024 | 12:10 AM
Don B's Avatar
Try searching just the number 10687 in the online catalogs for major bearing OEMs like Timken, SKF, Koyo, INA, NTN, VDO, ***, ZF, IBC, Stieber, ZEN, CSC, GRW, GMN, etc. You may get a hit.
Cheers,
Don
POD XF
Nov 13, 2023 05:28 AM
51rover
Mar 27, 2018 02:06 PM
MPB
E type ( XK-E )
Oct 19, 2015 09:32 AM
liquidreality
Sep 9, 2014 08:08 PM
Stuckonbrits
XJ40 ( XJ81 )
May 23, 2008 02:36 PM
