XJ40 ( XJ81 ) 1986 - 1994
1993 xj6 abs brakes won't unlock
Old Dec 4, 2011 | 12:14 PM
Hey Tan, moved you into the XJ40 section.
Hopefully one of our Tech guys will help out.
Old Dec 5, 2011 | 09:03 AM
gdstok's Avatar
Originally Posted by Tan4210
My mom has a 1993 xj6 jaguar she says the brake actetuator has a problem says the brakes won't unlock after they are applied. besides that eveything else is fine. I want to fix for her for christmas. It is the 1st car she paid off in full and she really loves it. Any help would be great.
What is she referring to as brake actuator? Pedal staying down? Pads remaining engaged after letting off the brakes? (front brakes or rear having the problem?)
If it is pads remaining engaged, it is most likely piston stickiing in caliper. Possibly master cylinder, but I think that is a rather rare failure for master cylinder. Probably need to pull the front wheels and remove caliper. If caliper piston is binding, eitehr needs cleaning or replacing.
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
