XJ40 ( XJ81 ) 1986 - 1994
1994 TEVES Brake Conversion?
Old Sep 7, 2018 | 06:35 AM
XJ12Dave's Avatar
Default 1994 TEVES Brake Conversion?
Hey Folks,
I am having trouble with my 1994 XJ12 TEVES bake system,
the car sat for 5 years and now I have problems with the system.
have done all the bleeding and so forth, starting to think maybe the "master cylinder" Accumulator mite be bad,
brakes always soft and sometimes fluid comes out of the top of the cap.
read somewhere about converting the system to the good ole vacuum assist power brakes.
have any of you done this?
thanks, Dave
Old Sep 11, 2018 | 06:54 PM
jerry_hoback's Avatar
I saw a thread awhile back about this conversion. I think he used a booster from a Series 3 xj. Try searching this or the Series forum. It shouldn't be too hard to find. BTW, did you bleed the rears properly? It calls for 2 people and cant really be done by gravity. Good luck.
Old Sep 12, 2018 | 04:56 AM
XJ12Dave's Avatar
Hi Jerry, going to try again this weekend, have 2 sons to help. think I might have to pull the elbow and drain the LP side first.
figured I would ask and search to cover all the options.
any other recommendations?
I read some where that the pressure ball might be bad on the accumulator.
thanks, Dave
Old Oct 18, 2018 | 09:48 AM
Brewtech's Avatar
The accumulator is prolly shot. Theyve gotten cheaper lately. They used to cost double. Anyway, stick with the Teves. Once repaired, it should be good to go. I had similar thoughts too when mine was acting up.
mikebaker3
Aug 3, 2015 08:34 PM
rama1200
May 18, 2015 07:29 PM
hoodun
Oct 14, 2014 11:14 PM
75Gremlin
Aug 24, 2014 11:13 AM
Vee
Sep 15, 2013 05:34 PM
