XJ40 ( XJ81 ) 1986 - 1994
1994 xj6 jag cranks but wont start what do i do
Old Feb 23, 2011 | 03:32 PM
MidwestJag's Avatar
theresa,
Welcome to the forum! Honestly, the very first thing I'd probably do is pull a relay from one of the other non-essential systems and swap out the fuel pump relay - probably located on your '94 in the engine compartment against the firewall. If that doesn't fix it, you're probably going to need to begin a battery of tests - confirming that you do not have fuel pressure at the fuel rail. If there is no pressure, it could be the fuel pump itself (that one would be a pain), or the fuel pressure regulator, or a few other things. If it is getting fuel but simply won't fire, a common culprit is the throttle position sensor (TPS). Any or all of these things, given their age and use, can get flaky.
cheers!
Scott
Old Feb 23, 2011 | 07:59 PM
Lumppy47's Avatar
Since you ran out of gas I would also put a new fuel filter as it may have filtered a lot of gunk from the tank
Old Feb 23, 2011 | 08:26 PM
Gus's Avatar
Gus
You can rent a fuel gauge at most any auto parts places like AutoZone.
Old Feb 24, 2011 | 04:06 AM
mrtalkradio's Avatar
Originally Posted by theresa
i ran out of gas put gas then it started ran for about 2 miles then just stopped.
Of course you understand that diagnosing a issue can only be as good as the information given. I'm not trying to be condescending, but you didn't say you put more gas in it. You said you ran out of gas, but then the car started again then stopped. Which could have used up every vapor in there. So did you add more gas? And if so how much? a Gallon? 1/2 Gallon? Did you use 93 and above fuel? Just asking.
Old Feb 24, 2011 | 02:15 PM
Oh man, that was naughty. LOL
Theresa, ribbing aside, sometimes when a car runs out of fuel even if no crud has been sucked into the fuel filters (which is highly likely it will have been), when you add more fuel and then try to start the car it can then crank until you kill the battery and still not start.
These modern fuel injected pressurized fuel system cars do not like running out of fuel.
Ex Mrs T was always running out, and when I did a roadside refuel I knew that I would have to jumper the car in order to get her car to crank fast enough and long enough to get the fuel up to the engine and back.
Read at least a full minute of cranking at full speed.
I hope that by now you are up and running, let us know how you faired.
Old Feb 25, 2011 | 07:34 AM
MidwestJag's Avatar
Sorry, I need to correct what I wrote above. I meant to write Crankshaft Position Sensor (CPS) not the TPS. TPS's can go wrong too, but when a CPS does, it will produce the non-start scenario described.
Any luck yet?
Scott
Old Feb 25, 2011 | 10:18 AM
retromotors's Avatar
... I'm not trying to be condescending, but you didn't say you put more gas in it. ....
Actually, if you look very carefully at the original post, the OP indeed stated that they had put gas in it.
Apparently in this age of textspeak, the ability to construct a coherent sentence is considered old hat.
u no wot i meen?
So it's up to us old pharts to attempt to decipher communications that use little if any of the accepted forms of punctuation, capitalization and structure that evolved to make the language understandable ... to make it "flow" and actually make sense.
Remember everybody, text often.
Do your share to contribute to the dumbing of America.
Old Feb 25, 2011 | 10:47 AM
MidwestJag's Avatar
Retro:
I'm not sure whether to take umbrage or not! Am I, in my mid-thirties, already to be considered an old Phart?! Or, are you simply living into the exalted category in these hallowed Jaguar Forums of "senior" member? (Although, truth be told, I did just this morning discover two gray hairs upon my face. Alas.)
lol.
Scott
Old Feb 26, 2011 | 03:45 AM
We've just had the full moon Scott so you should be OK for a week or two.
To whom?
I wonder if the car has now started again, it's been a few days.
Old Sep 7, 2011 | 01:22 PM
AdrianSw's Avatar
Waiting on news. Good i hope... :-)
Old Sep 7, 2011 | 02:09 PM
Most times, that I have found, is that when someone new comes here and resolves their problem they do not return. It's is we, the cat lovers that continue to return, greet new-comers, donate a little bit and add to the forum as much as we can.
1100me
Aug 27, 2020 11:37 PM
Drew2006
Nov 24, 2015 11:14 AM
1964Daimler
Sep 2, 2015 11:41 PM
cheaperts
Aug 30, 2015 06:48 PM
1100me
Aug 28, 2015 09:48 PM
