XJ40 ( XJ81 ) 1986 - 1994
91 jaguar xj6
Old Nov 26, 2012 | 08:39 PM
marcus6973's Avatar
Default 91 jaguar xj6
hello my name is marcus i am looking for some advice i have a 91 xj6
replaced tranny and the rotary switch the tranny i put in then took back out was a brand new tranny but that wasn't the problem it acts like it is stuck in limp mode like i have stated i replaced both tranny and rotary switch and it is still stuck in second gear it will not switch gears any and all advice would be appreciated thank you
Old Nov 26, 2012 | 09:18 PM
MidwestJag's Avatar
Marcus:
First off, welcome to the forum! Your problem must be very frustrating, especially if you have replaced the whole transmission. Did I understand that correctly? Please research in the archives both here and elsewhere on the internet the correlation between a flaky Throttle Position Sensor (TPS) and the infamous "limp mode" on these XJ40s and I think you will begin barking up the right tree...
Others will certainly chime in with other ideas. Cheers!
Scott
Old Nov 27, 2012 | 07:03 AM
marcus6973's Avatar
Default tps
yes i replaced tranny twice put old one back in
Old Nov 27, 2012 | 07:15 AM
marcus6973's Avatar
Default hello again
also i should state that the transmission/gearbox light is on
Old Nov 27, 2012 | 01:58 PM
marcus6973's Avatar
update it ended up being a bad wiring harness thank you
Old Nov 27, 2012 | 04:59 PM
michael prichard's Avatar
28th instant,
Marcus,
I am sorry to hear of all the labour you have expelled in trying to solve the problem. May I suggest that in future, you meticulously clean on a regular basis, the external casing of the Throttle potentiometer which you will find under the large barrel extending outwards from the engine going into the MAF. This can be seen (often red in colour) if you look at the top of the Oil filter. You will not have too many issues with the tranny or "engine check" lightif do the cleaning I have recommended.
Regards,
Michael Prichard,
Australia
Regards
rusty37
Jun 7, 2016 04:43 PM
97xj6lucy
Sep 3, 2015 07:44 AM
plums
General Tech Help
Sep 1, 2015 06:34 AM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
