XJ40 ( XJ81 ) 1986 - 1994
91 xj6 blower motor issues
Old Dec 18, 2010 | 02:50 PM
cargasm's Avatar
Default 91 xj6 blower motor issues
Hey everyone just got my first jag. First problem I'm trying to fix on it is the heater because its cold here in mass.
I checked all fan speed on heat and ac.
low, med, and high I get nothing at all
When I put it on defrost it will turn on for a second then makes a wierd noise (kind of high pitched I think its the right blower motor) on the right side of the dash then stop blowing.
Sometimes the left blower motor continues to run sometimes it doesn't. Right blower doesnt seem to run at all.
The fuses are good.
I have started with the right blower motor first.
The brown/blue wire going to the blower motor has 12v
The black wire in the same connector has a good ground.
What wire should I check to see if the blower motor is getting a signal to turn on?
Is there anything else I should check before pulling out the blower motor?
Thanks in advance for any help!
toronadomike
Jan 22, 2026 10:13 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
XJsc-guy
Sep 2, 2015 11:43 AM
