XJ40 ( XJ81 ) 1986 - 1994
'92 3.2 XJ40 brake warning light.
Old Aug 5, 2011 | 12:12 AM
direng's Avatar
Default '92 3.2 XJ40 brake warning light.
Hi all,
When I use my brakes the (o) warning light flashes on the dash each time I release them (as the brake pedal switch turns off). It was intemittant but now does it every time, even when I gently touch the brake pedal and just activate the switch.
I have checked the connections that I can see, the pads look ok, brake fluid is at the correct level and the brakes are working well. VCM says 'FAIL'.
Can anyone give me a heads up on this? low vacuum??
Old Aug 5, 2011 | 03:14 AM
Cadillac's Avatar
Is your brake wear sensors OK ? Mine flashed too .Also, make sure ABS works fine so is brake master cylinder
Old Aug 5, 2011 | 05:02 AM
Hmm, yours lights up when you release the brakes?? Mine flashed when I applied them. Duff accumulator sphere for me.
Check the inline brake fuses above the inertia switch, OZ car, right side above accelerator pedal.
Old Aug 5, 2011 | 05:18 AM
direng's Avatar
Thank you,
I will check out your suggestions and let you know how I went.
I have a vehicle hoist at my factory but will be away next week.
As this issue started out as an intemittent fault I didn't suspect a fuse - unless it is the fuse connection.
99xk8guy
Sep 29, 2025 10:51 PM
johndahlheimer
Sep 16, 2015 05:44 PM
fingers
Sep 11, 2015 12:21 PM
fingers
Sep 8, 2015 03:54 PM
edtexas
Sep 4, 2015 08:20 PM
