XJ40 ( XJ81 ) 1986 - 1994
94 xj6 wiper motor doesn't work at all
Old May 13, 2015 | 08:44 PM
jimbo94's Avatar
Default 94 xj6 wiper motor doesn't work at all
new problemhas started. my wiper motor doesn't work at all.I've checked all three fuses and chaged them out for new even though were good. then disconnected wiper motor from harness and have no power on any speed. I found a module behind driver headlight DBC11206 and has that for wiper and a timer for interior lights. the timer works but no wiper. Is this module common to just blow out? last time drove car in rain delay worked fine in a light mist then other day in the fog no wiper at all.These electrical problems are troublesome but gotta love the car. Any suggestions would be appreciated.
Old May 13, 2015 | 09:12 PM
jimbo94's Avatar
Sorry all didn't replace the fuse behind kick panel because what have read is only for intermittent delay part of wiper
Old May 14, 2015 | 10:33 AM
MidwestJag's Avatar
jimbo94:
I have no personal experience with this one, but my first reaction was to check whatever relay is responsible for the wipers. So, I think I would be sniffing around that relay module as well… Hope others smarter than me will chime in.
On a different note we live very close to each other. Your '94 doesn't happen to be a light green VDP, does it?
Scott
Old May 14, 2015 | 05:42 PM
jimbo94's Avatar
No mine is the maroon 94 xj6 small dent left front by front headlight . If around reedsburg during the week you will see it at my work unless on the harley. Thanks for the input. where you from?
Old May 20, 2015 | 06:56 AM
jimbo94's Avatar
Found the problem i hope. There was a wirecorroded off at the relat plug end. hope to solder it tonight. will let all know if that was problem for sure.
Old May 25, 2015 | 08:02 AM
jimbo94's Avatar
That was problem. Had to tear apart plug in harness 2 connections very corroded and 1 connection broke clean off. Soldered the connections and all works.Hope this might help others out there. Are thesecars prone to corrison and why?
chipnping
Mar 8, 2016 10:33 PM
johnnie ryall
Oct 19, 2015 09:44 PM
johanasu
Sep 3, 2015 12:39 PM
97xj6lucy
Sep 3, 2015 07:44 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
