XJ40 ( XJ81 ) 1986 - 1994
Airconditioner
Old May 15, 2007 | 02:28 PM
bigdreams05's Avatar
Default RE: Airconditioner
Be more specific please! Does your fan turn on but the compressor doesn't? Do they both turn on but it doesn't get cold? Does nothing turn on at all?
Old May 16, 2007 | 12:56 PM
Sometimes there can be a leak in the system, and when the refrigerant runs out, you could never tell if there where a leak. The system will prevent the compressor from turning on if the refrigerant runs out! Your fan will work fine, and your AC compressor should work fine if you recharge the system. Then just check where the leak is coming from and fix it. You could check your relays though, but that I think you would need the manual for!
Old May 16, 2007 | 04:35 PM
ken@britishparts.com's Avatar
Like at the row of relays on the passenger side firewall. The A/C clutch relay is second from the fender.
tilbury
Aug 8, 2012 09:17 PM
EZDriver
Oct 18, 2011 03:30 AM
sbrantley
Jun 4, 2011 10:40 PM
