XJ40 ( XJ81 ) 1986 - 1994
Anyone have instructions for an xj40 steering rack
Old Jul 21, 2021 | 07:55 PM
05strSATX's Avatar
Default Anyone have instructions for an xj40 steering rack
Gonna attempt to replace the steering rack in my new 91 xj6, have never done one and wondering if y'all got any idea how to do it. Thanks
Old Jul 21, 2021 | 09:10 PM
jerry_hoback's Avatar
Its actually quite easy once you jack the car up. The rack itself is held in by 4 bolts to the front cross member. There are two hydraulic hoses to undo, make sure you have a catch pan for the fluid. And then the tie rods- count the turns as you unscrew them and turn them back the same number to install (may not be same side to side) and then the steering column clamp bolt. Of course the order to remove should probably be reverse of that- tie rods, hoses, lower steering column connector, then mount bolts. I would have a "real" alignment done afterwards too. Change your fluid along with the new unit. Don't overthink this one.
Chris Okello
XJ40 ( XJ81 )
Oct 9, 2023 08:20 PM
Doug
Feb 4, 2021 07:40 AM
yachtmanbuttson
Aug 10, 2018 08:11 PM
ericschichtel
Dec 20, 2012 11:01 PM
Rique
Oct 2, 2009 03:19 PM
