XJ40 ( XJ81 ) 1986 - 1994
ATF Change
Old Jun 4, 2009 | 04:38 PM
jpskiller's Avatar
Default ATF Change
car xj6 3.2 1992
is it true that the only way to empty the TC on these is to drop the gear box, or is there another way to get to the TC plug
Old Jun 5, 2009 | 09:20 AM
ken@britishparts.com's Avatar
You can take it to a transmission shop and they can pump the fluid out from the oil cooler lines if they have the proper machine. The down side of this is to be extremely careful when removing the lines. The lines tend to take the threads off the oil cooler when removed. Then you've turned a simple fluid change into a costly repair.
Old Jun 5, 2009 | 12:53 PM
jpskiller's Avatar
thanks
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
