XJ40 ( XJ81 ) 1986 - 1994
automatic seat belt
Old May 27, 2020 | 09:25 PM
Roger95's Avatar
Default automatic seat belt
Stopped working today. Been working fine, no noise, no vibration, perfect working order, come out of the market, get in the car, turn the key and
nothing. The failure was so quick that I'm thinking electrical? In the morning I'm going to check any fuses and relays...
Any ideas?
Thanks,
Roger
Old May 28, 2020 | 09:41 AM
Don B's Avatar
Hi Roger,
I think you're right - it does give the impression of an electrical failure. There are several power circuits to the Passive Restraint ECM so you'll have to check all the relevant fuses and relays. The schematic is on pdf page 68 of the Electrical Guide:
Jaguar XJ40 Electrical Guide 1990
Those mechanisms were so fraught with malfunction that if I recall correctly, Jaguar had to eventually extend the manufacturer's coverage to a lifetime warranty, and some of our members have found that in recent years some Jaguar dealers will still honor that warranty if they can get parts. Use the Advanced Search function in the dropdown menu when you click Search above to search the forum for reports from other members. I assume there's a dealer in your area. I know there is one in Sarasota.
Cheers,
Don
Old May 28, 2020 | 06:46 PM
Roger95's Avatar
That belt worked fine today, no trouble whatsoever...?
Sarasota, Fl, been there. Sarasota the town in America where used car dealers sells Rolls and Bentley.
If you're ever in Sarasota have a meal at the Columbia Restaurant in St. Armand's Circle!
Old May 28, 2020 | 10:55 PM
Don B's Avatar
Could be an intermittent relay or corrosion on the ground point referenced by the PRECM.
We've spent many a Spring Break at Siesta Key, so we know the area well, including St. Armands, but I don't recall ever eating at the Columbia, so thanks for the tip!
Cheers,
Don
Old Jun 1, 2020 | 05:05 PM
jerry_hoback's Avatar
This will not Fix the Problem. But I recently discovered that if I smack the knee bolster just where my left knee would hit in a collision, I can usually make mine work. As an aside, I have already removed the control unit and tried the whole resolder thing with no noticeable improvement.
Sayed Ali Alqatari
Other Areas
Jun 19, 2018 03:18 PM
yardpro
Mar 19, 2011 05:17 PM
woodpuppy
XJ40 ( XJ81 )
Feb 12, 2009 07:53 PM
whiteSTR
Nov 19, 2008 04:55 PM
