XJ40 ( XJ81 ) 1986 - 1994
Bad ECU ?????
Old May 8, 2011 | 09:34 PM
Chris Heuer's Avatar
Default Bad ECU ?????
Need Help
I thought I had a faulty MAS or Throttle Potentiometer when my 1990 XJ would not go over 2500 RPM. I could put the peddle to the floor, but it would just suck air and slow down until you took your foot off the gas and the engine would run again. I was surprised when voltage test readings showed that they seemed to be OK, but the current from the ECU to the MAS was way too low. All the connections and wires are in good shape. It shows fault 18. I have replaced the fuel filter, checked the wires, plugs, distributor cap and air filter. The car cranks right up and runs fine until you get to 2500 RPM. Do you think it is the ECU?
Thanks,
Chris Heuer
Old May 8, 2011 | 10:27 PM
Trick Freestones's Avatar
"Suck air" or hissing?
Sounds like you should check for a plugged up cat (catalytic convertor) or cats, Chris.
Old May 9, 2011 | 08:01 AM
xjrguy's Avatar
I'd get a fuel pressure gauge on your engine. What you describe sounds to me like a fuel pump that can't keep up. And the code 18 fits with that, too. That code sets because the ECM knows that if you open the throttle and the RPM's and air flow don't follow, something is wrong, up pops code 18.
Trick could be right about the cat, but I'd check the pump first.
Cheers,
Old May 11, 2011 | 04:48 PM
mrtalkradio's Avatar
Good stuff Steve,
These fuel pumps cause a lot of issues, masked by a lot of symptoms.
Bcrary3
Sep 12, 2021 05:41 AM
Johncy2000
Dec 22, 2017 04:32 PM
knightofgold
Feb 11, 2016 06:03 PM
Charlene n John
Sep 14, 2015 12:01 AM
joesoap
Sep 10, 2015 01:09 PM
