XJ40 ( XJ81 ) 1986 - 1994
Blower working on high only
Old Feb 11, 2011 | 06:03 PM
roger ele969c's Avatar
Default Blower working on high only
Originally Posted by BigAlum
Blower motor just started working for no apparent reason? It's not a fuse. I'll lay odds on a glitch that the early XJ40's had in the climate controls.
it was fixed on later models by addition of a capacitor soldered into the wiring on the back of the control panel. You'll see this referenced in other threads, but no one seems to know where the capacitor goes. The Haynes manual addresses the fix and lists a factory part # for the capacitor and says the instructions for installation are included with the part. Some have told us in the threads that the instructions are NOT included. Just so you know, my '88 XJ40 does the same thing - it'll work fine for a while, the not work at all for a while, and sometimes, it'll work intermittently from day to day...I just don't know. My plan is to find a '90-'94 version in the wrecking yard to compare wiring. Good luck. Like you, I love the ride of these big Jaguars.
Hi, I think you probably should have started a new thread for this, anyway, I've got a '93 and the blower only works on high. If you go to 'search' and type blower motor you will get some excellent writeups ......Roger.
Old Feb 11, 2011 | 08:03 PM
Gus's Avatar
Gus
I found a oneline on your year car and on page 79 you may find the information you need. Take a look and see if it helps http://www.captainjaguarscathouse.co...ec%20Guide.pdf I hope this helps and I will set it up on a new post.
Old Feb 12, 2011 | 08:10 PM
Thanks Gus, I couldn't find any page numbers and don't know what I should be looking for. When it comes to electrics I'm particularly useless ! I guess I should check fuses first, should I ?......Roger.
Old Feb 12, 2011 | 09:46 PM
Gus's Avatar
Gus
It is Fig 29 It gives you the relays to check. This oneline will also give you the locations in the car for you to find them. Do not let the oneline intimidate you, just take your time. I am not familiar with that car to provide specific help. If you can locate the relays for the system you can try to swap one relay with another like relay it the problem disappears then replace the relay you pulled. I hope this helps.
Old Feb 13, 2011 | 05:37 PM
Thanks Gus, I can see mention of one relay only, on the left front inner fender. So I assume it does both......Roger.
Old Feb 13, 2011 | 05:47 PM
Gus's Avatar
Gus
Roger,
It looks like you are on the right track right inner fender engine compartment. I had a 93xjs with an ac problem and it about drove me crazy. At that time I did not have a oneline and did most of it with a volt meter and tracing wires and lines. You can do this! It would be great to see if we had an expert in this area to help you.
Russ Graber
Feb 23, 2019 11:59 AM
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
