XJ40 ( XJ81 ) 1986 - 1994
Brake and abs lights appear. what's wrong?
Old Jun 26, 2010 | 03:29 AM
Perhaps repost this in the XJ40 area, that is the car you have.
I am going to give my best guess, others will definately come in with other ideas.
Anti-lock light, more that likely a wheel sensor not giving good contact, lose/unplugged/dirty contact.
The brake light on the dash may be the "bomb" going/gone flat, it is a service replacement item. It may also be the cause of the Anti-lock light, dunno.
Old Jun 26, 2010 | 03:36 AM
Cadillac's Avatar
I have moved it off to the XJ40 Forums ,I hope you get it sorted out soon
Old Jun 28, 2010 | 09:57 PM
gunnerman's Avatar
Hate to tell you this but the worst thing about these cars are the brakes. Are your brakes still working or do you need to press excesively hard to stop?
To me it sounds like the brake accumulator ball has gone bad on the ABS pump asasembly. The Pump pumps a nitrogen filled ball (diaphragm) with brake fluid. This ball has a valve to let pressure out of the ball and into the brake system to gain power assist brakes. A lot of the times the accumulator ball goes bad and so anytime you press the brake the pump turns on for brakes or the pump runs excessively and burns itself out.
A check for this is to have the car running and listen to the abs pump assembly and see if the pump runs/clicks on and off when there is no brake use. Also have a friend press the brakes while you are watching. Does the pump run every time he presses the brakes?
It could also just be faulty ABS speed sensors, these cars are known for dirty brakes that clog the sensor easily. If the ABS pump seems to be doing fine I would clean up all of the sensors and see where that takes you.
Old Jul 1, 2010 | 12:57 PM
BREATTHEE's Avatar
I have that issue with my jag. i guess you would have to replace the nitrogen filled ball to make it right again?
Old Jul 1, 2010 | 04:31 PM
ken@britishparts.com's Avatar
Correct. This one fits the 90 to 94:
http://www.motorcarsltd.com/_search....ge=1&q=jlm1907
Old Jul 8, 2010 | 07:39 PM
Robert's Avatar
The BRAKE light on the dash of my 1990 XJ6 Sovereign used to come on whenever I pressed on the brake pedal. It was that way when I bought it about 2 months ago and I thought it was supposed to. I read through the owners manual and realized that it was telling me that I needed brakes. I went to replace the front pads and found that the left front brake sensor harness was missing. I bought a replacement harness for $21.00 and installed it. The BRAKE light switch immediately went off and has not been on since.
toronadomike
Jan 22, 2026 10:13 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
innzane
Sep 2, 2015 10:08 AM
