XJ40 ( XJ81 ) 1986 - 1994
Brake Issues
Old Apr 8, 2012 | 06:58 PM
limegreenclown's Avatar
Default Brake Issues
On my 91 I've been having some brake problems, I started to notice that at stop lights the pedal would sink to the floor. After some research I decided to replace the master cylinder but with this being a teves system a new one is ~$1800 so I picked up on out of a scrap 93, replaced the master cylinder, booster and abs block all at once, bled the brakes(I had to look up how to to this too) and the end result. Possibly worse than when I started. The thing is if I'm going down the road and slam on the brakes the car stops fine, and the abs works. I have an accumulator sphere on order but I'm open to suggestions on other things to test/replace because I need my car and I dont feel safe driving it like this.
Old Apr 8, 2012 | 08:08 PM
Lumppy47's Avatar
Are you sure you bled the brakes correctly. The fronts are bled like any other vehicle, but on the rears you have to turn the key on and let the pump push the air out (do right side first then left side). Usually after they are bled it should take a few minutes for the pedal to come up,then they should work fine.
Old Apr 8, 2012 | 10:30 PM
edselsouth1's Avatar
Default Brake issue
limegreenclown.... I had similar problems w/ a Teves system on my Reatta. Took a while to sort it out. THere is a procedure to test for a faulty component on a Teves system, for the Reatta, and it may also be a usefull tool in diagnosing your problem. Go to aaca.org, goto forums, goto Reatta, and do a search.There are plenty of threads on the Teves. Hope this is helpful in diagnosing your problem. (Also, PM sent on another subject). David.
Old Apr 9, 2012 | 08:38 AM
mrtalkradio's Avatar
Gotta bleed em my man........Jaguar style!
Old Apr 9, 2012 | 09:29 AM
Thank you for your responses. I have checked out the reatta site and it is helpful. My accumulator should be in tomorrow so my plan is replace that and re bleed the brakes
Old Apr 10, 2012 | 06:51 PM
Just got the accumulator in, put it on and I had pedal for a second and then a front brake line split on me. So I've ordered a set from david manners and they'll eventually get here
Old Apr 11, 2012 | 02:49 AM
On the plus side, at least now you can get pressure in the system.
Bust brake lines, not withstanding.
Hope all goes well.
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
obwoodie
Sep 3, 2015 07:45 PM
