XJ40 ( XJ81 ) 1986 - 1994
Brake Pad Sensor Missing
Old Jun 26, 2010 | 03:06 PM
Robert's Avatar
Question Brake Pad Sensor Missing
The PAD warning was showing on my 1990 XJ6, so I was going to replace the pads. When I pulled the wheel and checked the pads, there was plenty of pad, but there is no sensor. When there is no sensor, and no sensor wiring to connect into the wiring harness, will the PAD code show? If so, is there a jumper that can be installed to turn off the PAD warning?
Old Jun 26, 2010 | 10:33 PM
JagtechOhio's Avatar
The chassis harness terminates at a bracket adjacent to the upper ball joint, LF only. Two pin socket, jump them to extinguish the warning light.
Fix it correctly with the sensor lead that plugs into the chassis harness socket, should be no more than a $25 item. The business end just clips into a cutout on the brake pad backing plate.
Old Jun 27, 2010 | 07:03 AM
Robert's Avatar
Thanks for the feedback. There is a Jaguar shop here in Tulsa with a parts department. I'll check with them this week.
Old Jun 29, 2010 | 06:44 PM
Robert's Avatar
Purchased the sensor wire and installed same. Cost was $21.00 plus tax. All is good in my world.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
JagLove86
Sep 6, 2015 10:36 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
