XJ40 ( XJ81 ) 1986 - 1994
cannot lock my doors on 90 xj6.
Old May 12, 2010 | 10:44 AM
jessy69h's Avatar
Default cannot lock my doors on 90 xj6.
i got the car 2 days ago and live in a not so great part of town and i cannot lock any of my doors. i can only turn my key to the left in the door and i cannot push the knobbies down manually in the car either. i was looking online to see if i could find n e thing but i havent had any luck. i was looking in some other threads and saw aomeone mention a boot for it where is it and will it help my situation lol. thanks very much,
Jessy
Old May 13, 2010 | 11:31 AM
sogood's Avatar
That could be a multitude of things! You should start by checking relevant fuses (dont know wher they are on your model, sorry) and relays also. You dont say if you've tried locking etc. with the remote, do you have one? The locks may have to be synchronised, as had happened to me with an old BMW. It involves a process of opening and closing, (locking and unlocking) in a particular order. Maybe try a search on the forums here, lots of useful info. It does sound electrical though, perhaps a blown fuse, bad connection/ earth. I'm always happier when something just plain doesn't work, full stop, rather than an intermittent problem, which tends to be harder to pin down. Sorry not to be of much help, but do a search and good luck.
Old May 20, 2010 | 09:10 AM
Davedz's Avatar
I also recently acquired a '90 XJ6 and had quite a few door lock issues, including one broken door handle. My locks were very stiff, to the point that I could not use the internal lock knobbies on the rear doors. I sprayed WD-40 and silicone lube on the latches and inside (thru child lock switch opening) as best as possible, and worked them up and down. This got them working manually. I still have one rear door handle/lock that is stiffer than I am comfortable with so I will pull the door panel and shoot some lube inside.
Good luck!
Dave
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrsimpson
Sep 15, 2015 01:10 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
