XJ40 ( XJ81 ) 1986 - 1994
Car died and will not start, did LOTS of diagnostic tests
Old Apr 2, 2020 | 03:53 PM
JensenHealey's Avatar
Default It's FIXED!
It was the ignition rotor.
So if you think you have spark and after much screwing around and yanking of hair and "thinking" you have spark, ALWAYS try replacing the ignition rotor.
Old Apr 6, 2020 | 01:11 PM
I had questions about the results of my dead car solution over on the Jag-Lovers XJ40 forum so I thought I would post my answer here too. I hope this is not against the rules here.
The ignition rotor in the XJ40 has a resistor inside of it that provides the connection between the tip and the center of the rotor. So all of the spark energy has to pass through this resistor and sometimes this resistor decides it has had enough. At that point it totally stops transmitting the spark through the rotor. In my case it was only partially dead so I “sort of” had spark at the plugs but not enough to actually run the car.
Normally there is absolutely NO spark at the plugs but there will still be spark energy being transmitted through the coil wire. It just won’t make it out through the cap to the plugs.
So yes, as others have said here, it is ALWAYS wise to carry a spare ignition rotor in the car. Possibly also a spare crank sensor.
Old Apr 6, 2020 | 01:23 PM
Don B's Avatar
Originally Posted by JensenHealey
... it is ALWAYS wise to carry a spare ignition rotor in the car. Possibly also a spare crank sensor.
Agreed - I highly recommend installing a new CPS in your Jaguar and putting the old, working one in your boot as an emergency spare. The CPS and distributor rotor button are so easy to replace, you'll kick yourself if you become stranded away from home because one of them has suddenly failed and you don't have a spare with you.
Jimmy Waldhalm
XJ40 ( XJ81 )
Oct 20, 2019 01:22 PM
rfarmery
Apr 2, 2017 10:13 AM
gwlones
Nov 17, 2016 10:26 AM
trguy75
E type ( XK-E )
Jul 6, 2016 01:36 PM
cuengineer
XJ40 ( XJ81 )
Apr 22, 2012 10:38 PM
