XJ40 ( XJ81 ) 1986 - 1994
Change to Square headlights
Old Oct 23, 2015 | 10:12 AM
Stilling's Avatar
Default Change to Square headlights
Hi bare with me im new to Jag
But is it possible to change from 4 round to square headlights easy ?
Or is that a total Jaguar no go ? or is that the same as to hitting the start botton for a oil debate ?
Old Oct 23, 2015 | 11:51 AM
manwich66's Avatar
Now that's an oil debate if I saw one!
I am sure it's do-able,these cars came with either -or.
I have yet to get to the lights on my parts car,Cin prefers the roundies anyway.I think the squaries give more usable light,IMO.
Cheers,Jim.
Old Oct 23, 2015 | 09:20 PM
Don B's Avatar
Originally Posted by Stilling
... is it possible to change from 4 round to square headlights easy ?
Hi Stilling,
Yes, it's absolutely possible to make the switch. I went the other way and replaced our rectangular lamps with the quad round lamps. The main thing you will probably have to do is to either change the two front Bulb Failure Modules (BFMs) or splice in new electrical connectors for the bulbs.
On our '93 I used Cibie round lamps that use H4 and H7 European style bulbs, so I just replaced the electrical connectors on my existing BFMs.
The lamps just attach with a few screws, but you need to remove the grill to access some of them. The grill inserts attach with just four Phillips head screws, then the grill is attached with a few hex head screws or nuts.
Let us know if you go through with the swap and please post some photos showing the process if you can.
Cheers,
Don
Old Oct 30, 2015 | 02:24 AM
Stilling's Avatar
I decided that i want one of each model / engine type, so half with rectangular and half double round headlights, but many are in pretty bad shape so i thought it i find them all with round headlights i could just switch headlights on some of them.
teacoff
Nov 27, 2022 05:36 PM
DandyAndy
Nov 17, 2015 04:07 AM
Snide72
Nov 2, 2015 03:02 AM
Rocky15
Sep 28, 2015 04:59 PM
kevinl
Sep 24, 2015 08:25 PM
