XJ40 ( XJ81 ) 1986 - 1994
HSMO leak
Old Oct 30, 2015 | 04:34 AM
xjack's Avatar
Default HSMO leak
Hi There
This is 89 xj40, with sls removed but system in place
I have finally rebuild accumulator/pressure switches module hoping for the best, but guess what? HSMO keeps leaking. Well, this time leak comes from the top of bay/fender, drips somewhere in between pump feed hose and reservoir but thick layer of dirt-oil paste covering engine prevents me from see the source. It seams to leak when car is hot, after some driving, so i thought it leaks from pressurized part of the system, but as far as i understand neither reservoir not feeder hose are under pressure.
My bet is pump feeder hose but i ask you for some more ideas before start braking things apart
Regards
Sean W
Nov 14, 2015 08:28 PM
TomFType
Oct 21, 2015 12:06 PM
Catsgame
Oct 21, 2015 08:46 AM
ChuckB
Oct 18, 2015 06:50 PM
Johnken
Oct 13, 2015 08:22 PM
