XJ40 ( XJ81 ) 1986 - 1994
Changing head gasket.
Old Mar 30, 2013 | 04:36 PM
PerErs's Avatar
Default Changing head gasket.
Dear all,
My owners manual suggests I remove the bonnet (hood) as a first stage to removing the cylinder head. Is this absolutely necessary? Is it also necessary to remove the cams from the head also. I was planning to set everything to TDC, mark accordingly and remove the upper timing chain by unbolting the sprockets from the cams. Am I missing something here? The head gasket seems due for replacement and I don't see the need to mess about with the cams. All advice very welcome!
PerErs. XJ40 (1990) 4.0 litre. Manual.
Old Apr 2, 2013 | 08:00 AM
MidwestJag's Avatar
HI PerErs:
First off, welcome to the forum! Don't forget to introduce yourself in the intros section.
I've never done the head gasket, and undoubtedly would never try. But, I do know that the bonnet is easy to remove and if I were doing the work, I'd want the best possible access. Don't forget, the head will be very heavy.
I also hope you are planning on doing the valve seals as long as the head is off. That's standard practice.
best,
Scott
Old Apr 19, 2013 | 05:42 AM
jaguar jon02's Avatar
getting the hood off makes it a lot easier. but you don't have too. i've did a few of them and sounds like you're on track. been so long i can't remember about head bolts ,but i don't think i took the cams out. why does it seem gasket needs replacing? they are bad or not
Old Apr 29, 2013 | 09:56 AM
mrtalkradio's Avatar
Hood off as noted above makes the job a whole lot easier.
Cams do not have to come out.
aholbro1
Dec 29, 2024 06:46 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dicque
Sep 19, 2015 12:53 PM
Dz1rfj
Sep 16, 2015 03:44 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
