XJ40 ( XJ81 ) 1986 - 1994
Cold air blowing on legs - Xj40
Old Jan 21, 2010 | 06:48 PM
gti69's Avatar
Default Cold air blowing on legs - Xj40
Hi,
When I trun on the heating in my XJ6 (XJ40), 3.2l, 1993 Jaguar, it works fine, apart from blowing cold air on legs all the time. Even when the system is set to high temperature, it is still blowing cold air on foot.
Any ideas?
Thanks for your help.
Tom
Old Jan 31, 2010 | 11:18 AM
Project Jaguar's Avatar
Probably an odd question, but where is this blowing coming from?
Is it coming right from "down under" where the pedals are?
Just because mine blows cold air too, and I have noticed its from the steering column hole (under the steering wheel) and I am going to get to the bottom of it one day I hope, but its at the end of my importance list ATM lol!!
I only really noticed it as the weather got colder, and even then its not EVERY day, so I wonder if it depends on wind direction and cold wind from outside being blown in from side vents...? Just ideas... *shrugs*
Old Feb 1, 2010 | 12:21 PM
ken@britishparts.com's Avatar
Check the grommets in the firewall. I'll bet it is nothing too series.
Old Feb 1, 2010 | 12:23 PM
Originally Posted by gti69
Hi,
Any ideas?
Tom
Remove the RH center console panel. At the top you will see two servo motors that control the flaps. Wrap on them with the handle of a screw driver and see if they move. If not, you may be looking at a vacuum problem on an ECU problem.
Old Feb 1, 2010 | 02:13 PM
Ahh thank you! I doubt it is anything too serious either, hence being at the bottom of my to do list (but I did first check for a gaping hole created by rust in the bulkhead! You know what these 40s are like!!)
02jagstype
23
Oct 23, 2022 07:03 PM
tonyforman
Sep 10, 2015 07:23 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
