XJ40 ( XJ81 ) 1986 - 1994
Comfort control module
Old Feb 21, 2020 | 07:07 AM
Gerard's Avatar
Question Comfort control module
Can anyone tell me what the COMFORT CONTROL MODULE actually does? I am building a kit car based on a jaguar XJ40 and would like to remove modules that are not neccessary.
Old Feb 21, 2020 | 08:29 AM
Gerard's Avatar
i imagine it is just the heater control, but want to be sure before i cut the wires out!
Old Feb 21, 2020 | 09:43 AM
Don B's Avatar
Hi Gerard,
I can't recall Jaguar using the term Comfort Control Module to describe any component in an XJ40. The Climate Control Unit (CCU) is the main central assembly that contains the heater core, A/C evaporator, blend flaps/drums and solenoid motors. The Climate Control Microprocessor (CCM) is mounted on the right side of the CCU. If I recall correctly, the early XJ40s (2.9L/3.6L engines) had a three-position selector on the control panel that gave three different "humidity" settings to adjust the incoming air for passenger comfort...
What year and model is the XJ40 you're working with?
Cheers,
Don
Old Feb 21, 2020 | 10:52 AM
Gerard's Avatar
Hi Don, thank you again. the module i am refering to is the "DBC 4966". When i search the web it said it was the comfort control module. The car is a 1990 4.0 litre XJ40 model.
Old Feb 21, 2020 | 02:30 PM
Don B's Avatar
Hi Gerard,
That is the Engine Control Module, or ECM, the computer that controls the fuel injection, ignition timing, coordinates with the Transmission Control Module (TCM) for smooth gear shifts, etc. Depending on what you are doing, you may not be able to run the engine or transmission without it.
Cheers,
Don
Napster
Sep 4, 2019 04:47 PM
03Xtype
May 16, 2016 09:57 PM
hafren
Aug 18, 2015 10:46 AM
etaent
Sep 13, 2014 08:45 AM
Novo
Jun 27, 2011 08:22 AM
