XJ40 ( XJ81 ) 1986 - 1994
Daimler Sovereign: No crank or dashboard lights
Old Apr 2, 2025 | 03:29 AM
OccultScientist's Avatar
Default Daimler Sovereign: No crank or dashboard lights
Hi all,
I've recently inherited a 1990 Daimler Sovereign from my late father. It's been off the road for a few years and isn’t in the best condition, but I managed to get it home from London on a recovery truck.
The first step was replacing the battery. When I turn the key, I can hear the brake servo/hydraulic pump kicking in, but I’m not getting any dashboard lights at all, and the engine won’t crank. I can hear the starter relay clicking under the glovebox, and it seems to warm up slightly after a few tries.
I’m thinking about getting underneath and giving the starter a gentle tap, but I’m not sure that would explain the completely dead instrument panel—so I’m wondering if that could point to a separate issue, maybe a bad earth or an ignition fault?
Also worth noting:
  • Remote central locking isn’t working—could just be the battery in the fob, but I’m wondering if it could also be related to the immobiliser not disengaging?
  • The car was able to be pushed in drive (so maybe a neutral safety switch issue?)
Just trying to figure out the best place to start with diagnostics—any advice much appreciated!
Thanks in advance.
Old Apr 5, 2025 | 01:38 PM
xjack's Avatar
i would start from inspecting all fuses and later grounds
can you turn the engine by crankshaft pulley?
safety switch is just a second, so have a look there too, but with it tripped car wouldn't click relays at all
St. Stephen
Apr 12, 2025 03:29 AM
4catstudio
Jul 26, 2024 04:13 AM
Oliver94
Jan 24, 2024 05:56 AM
GetItOn
Apr 17, 2019 09:39 AM
Sarc
May 30, 2015 04:57 PM
