I have a 1988 Vanden Plas but I believe this part should be the same for all model XJ40 years. I'm looking for the front door jam rubber that covers the wiring in the hinge area. I can't seem to find any listings for the part or any part numbers. Below is a picture of one from an XJ8. It's the accordion style rubber the goes in the front door jam and protects the wiring. Does anyone know if these are still available new or being reproduced or am I stuck with buying a 25+ year old used piece of rubber? If anyone knows of a part number it may help in my searches. Also,if you might have a good used one available I may be interested. Thanks!
Both parts are listed as No Longer Available, but you might check with David at everydayxj.com and Kevan at growlerparts.com since they often get NLA parts.
Unless I'm mistaken '93 cars come up on that site as having the AJ16 engine so double check everything (correct part numbers etc) if you order from them.
I looked at a random A/C part, one of the charge hoses ...US$1,071.00 ...Yeah, good luck with that!
