XJ40 ( XJ81 ) 1986 - 1994
Door Jam Rubber Wire Loom Cover
Old May 23, 2017 | 09:50 PM
95Leaper's Avatar
Default Door Jam Rubber Wire Loom Cover
I have a 1988 Vanden Plas but I believe this part should be the same for all model XJ40 years. I'm looking for the front door jam rubber that covers the wiring in the hinge area. I can't seem to find any listings for the part or any part numbers. Below is a picture of one from an XJ8. It's the accordion style rubber the goes in the front door jam and protects the wiring. Does anyone know if these are still available new or being reproduced or am I stuck with buying a 25+ year old used piece of rubber? If anyone knows of a part number it may help in my searches. Also,if you might have a good used one available I may be interested. Thanks! Door Jam Rubber Wire Loom Cover-jaguar-door-jam-wire-loom-cover.jpg
Old May 24, 2017 | 12:01 AM
Don B's Avatar
Jaguar calls that a "convoluted sleeve." The front door part number is DBC1093 and the rear door part number is DBC1094.
Here's the diagram:
Here's the link to the page:
https://www.jaguarclassicparts.com/uk/part/DBC1093
Both parts are listed as No Longer Available, but you might check with David at everydayxj.com and Kevan at growlerparts.com since they often get NLA parts.
Cheers,
Don
Old May 24, 2017 | 09:22 PM
95Leaper's Avatar
Thanks Don. I did a search with your part numbers and located the parts for $3 and $4. I already ordered them and they're on the way. Thanks again!
Old May 24, 2017 | 09:56 PM
XJSolver's Avatar
Is there any possibility of please sharing the link from where you found these for sale? Every time I search I come up empty.
Old May 24, 2017 | 10:05 PM
95Leaper's Avatar
Here's the site I purchased them from......Jaguar Parts International .
Old May 24, 2017 | 11:51 PM
Lawrence's Avatar
Unless I'm mistaken '93 cars come up on that site as having the AJ16 engine so double check everything (correct part numbers etc) if you order from them.
I looked at a random A/C part, one of the charge hoses ...US$1,071.00 ...Yeah, good luck with that!
https://www.jaguarpartsinternational...9191-78301.htm
Listed at the same price as the compressor so possibly a mistake ...still though, sloppy cataloguing - so be careful!
Larry
