XJ40 ( XJ81 ) 1986 - 1994
Driver’s Window won’t roll & Right mirror fault
Old Jul 2, 2018 | 09:19 AM
Kang Yu's Avatar
Default Driver’s Window won’t roll & Right mirror fault
Hello guys, this is 1993 XJ40(XJ6) owner from Taiwan.
My XJ40 driver’s window wont roll,
and sometimes when I open door to 45 angle it can roll, but it will fault again later.
I open my door card and reorganize window switch box but still doesn’t work, and my Right side mirror suddenly doesn’t work too, anyone can help me!
Old Jul 2, 2018 | 03:59 PM
jerry_hoback's Avatar
If your window will work when the door is open, it seems like you should look at the area of wiring that flexes when the door opens. You may have a broken wire (or two with the mirror) at the body -to- door area. Good luck.
Old Jul 3, 2018 | 01:34 AM
Kang Yu's Avatar
the right side mirror can left and right moving,
but can’t up and down moving
Old Jul 3, 2018 | 06:01 AM
Check for corrosion or a loose plug at the switches and at the plugs to the motors too. The mirror has separate wires for up- down and left- right. When removing the trim panels the wood slides forward off of clips and there is a screw hidden behind the air tube at the top front, besides all of the normal places....
nd4spdlsc
Nov 26, 2019 07:43 PM
Jaguar Forums Editor
Jaguar Press release
Jul 31, 2017 03:18 AM
Jul 25, 2017 08:38 AM
Jaggyx
Jun 6, 2010 09:41 PM
BurgXK8
Mar 3, 2010 10:25 PM
