XJ40 ( XJ81 ) 1986 - 1994
Front turn signal
Old Nov 15, 2021 | 07:16 PM
garageman's Avatar
Default Front turn signal
My 1990 XJ6 has a burnt out front turn signal. I removed the lens and with much difficulty got the old bulb out. There is very little room for my fingers to turn the bulb. Now I can't get the new bulb to turn so it will seat properly. What is the trick to this?
Old Nov 16, 2021 | 02:45 AM
Welcome to the forums garageman,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Old Nov 16, 2021 | 07:50 PM
jerry_hoback's Avatar
i dont remember myself, Is it an 1157 bulb? If so then the lugs are not at the same depth. youll need to make sure you have the shallow lug in the shallow slot. Simple things first..... Good luck.
Old Nov 21, 2021 | 05:22 PM
garageman's Avatar
I've done that. The problem is there is not enough room inside the bulb mount for my fingers to get a good grip on the bulb so as to turn it. Any suggestions? I have ordered a bulb wrench which hopefully will help.
Tiger88
Aug 29, 2013 12:30 AM
firetapped
Aug 4, 2011 03:03 PM
dmchilton
Mar 11, 2010 11:20 PM
Dallas4lr
May 6, 2008 05:08 PM
Waynepoe
Mar 7, 2008 08:04 PM
