XJ40 ( XJ81 ) 1986 - 1994
Front window cracked help!
Old Dec 8, 2010 | 12:11 PM
rolexmike's Avatar
Default Front window cracked help!
Hello fellow Jaguar forum members!
(long story)
About a week ago i was getting a box out of my attic and i tripped and went right through the dry wall and a board from the attic hit my windshield and cracked it. I called my insurance company because all auto glass is covered, two days later the gentleman showed up to replace my windshield and said, " I have to order the molding for around the window because it cannot be reused." They where very friendly and ordered the molding through a Jaguar dealer for me however, today they called and told me the parts came in but its the wrong molding and Jaguar no longer supplies the molding. Does anybody know where i can order the molding and frame for the windshield? Or if the old molding and frame can be reused? thanks again!
Old Dec 8, 2010 | 06:23 PM
Toller's Avatar
It will really help folks help you if you posted the year, make, and model of the car and your locale.
Old Dec 8, 2010 | 09:11 PM
rolexmike's Avatar
Absolutely eric,
It's a 94" xj40 VDP, I am located in east central Florida. Sorry I did not post that earlier.
Old Dec 9, 2010 | 03:14 PM
Toller's Avatar
You might try entering "Jaguar and parts" in a search engine. When I added "Georgia" to the search, up popped Coventry West (Atlanta). Then I looked a but deeper and....
http://store.coventrywest.com/cgi/co...pl?CTGY=JAG145
Eric
Old Dec 9, 2010 | 03:25 PM
Fraser Mitchell's Avatar
The words "cannot be re-used" may not be entirely correct. I would think the moulding can be re-used, but to extract it for re-use without damaging it in the process is probably very time confusing, and this is a risk that the screen company won't want; they want easy and quick jobs, and who can blame them.
It might be better for you to take off the trim and cracked screen yourself, and see of you can extract the moulding intact and undamaged. These mouldings can be very difficult to remove without damage as they are also secured by the screen adhesive. Also a screen that has been in as long as yours tend to be much more difficult to remove.
Normal removal method is to use cheesewire to cut the screen seal; there is normally a piece of moulding that is removed to let you push a bradawl through to make the hole for the cheese wire. I watched a technician replacing the windscreen on my Mazda Xedos a few years ago, and it is not an easy job getting the screen out even having the necessary tools. Do you know anybody local in the trade ?
Old Dec 9, 2010 | 03:29 PM
I also found this on the 'net. Says it all, basically
http://www.xj40.com/viewtopic.php?f=26&t=1605
Old Dec 11, 2010 | 08:41 PM
rolexmike's Avatar
Thank you all for the reply's! Turns out that Jaguar does still make the molding its just the guy at the auto glass place was asking for the wrong molding and putting me though this trouble So i went to a different glass company and they ordered it for me, all post photos to soon guys!
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
KarimPA
Sep 12, 2015 08:15 AM
ftypel
Sep 5, 2015 10:15 PM
