XJ40 ( XJ81 ) 1986 - 1994
Heater control 1994 XJ6 Sovereign
Old Jun 28, 2019 | 09:01 AM
Cj Murray's Avatar
Default Heater control 1994 XJ6 Sovereign
Hello.
The heater control on my Jaguar XJ6 Sovereign lights up and works when I first start the car, then doesn't work for the rest of the day. Anny suggestions as to what the problem might be?
Thank you.
Cj Murray
Last edited by GGG; Jun 29, 2019 at 04:06 AM. Reason: Remove signature icons which were locking the thread
Old Jun 29, 2019 | 04:04 AM
Welcome to the forums Cj Murray,
I've moved your question from General Tech Help to XJ40 forum. This is the place to post technical questions about your model of XJ6.
Old Jun 30, 2019 | 11:16 AM
Don B's Avatar
Hi Clem,
Welcome to the Jaguar Forums! It's great to have you with us!
From your description, it is difficult to fully understand how your heater system is malfunctioning. When it malfunctions, do the lights extinguish? Or do the lights remain illuminated, but the controls do not work? Which controls are not functioning properly? Temperature setting? Fan speed? Vent selection? Please give us some more information to give us a chance of helping you.
Cheers,
Don
Old Jun 30, 2019 | 11:37 AM
Cj Murray's Avatar
Default Heater XJ40
Originally Posted by Don B
Hi Clem,
Cheers,
Don
Thanks for the reply. Usually there is nothing, like the plug got disconnected. Worked perfectly yesterday all day, though. I'm going to try the A/C today.
This is my baby!!! 💚☘🇮🇪
Old Jul 1, 2019 | 09:22 AM
Don B's Avatar
Hi Clem,
It is possible you have a problem with an electrical connector that is loose or corroded. Corrosion on ground points is very common. Another common issue with the XJ40 is cold, starved or cracked solder joints in the relay modules and fuse boxes. Not usually difficult to repair by re-flowing and supplementing the solder, but time-consuming to track down. You can download the Electrical Guide at the link below, which will help you see which relays and fuse boxes are involved in your climate control system:
Jaguar XJ40 Electrical Guide 1993-1994
Cheers,
Don
Old Jul 15, 2019 | 07:58 AM
Lucylello's Avatar
Hi Same problem on My 1990 xj6 4.0
Cj Murray
Jul 1, 2019 07:18 AM
JensenHealey
XJ40 ( XJ81 )
May 15, 2019 10:51 PM
makula
XJ40 ( XJ81 )
Feb 14, 2017 12:37 PM
Phantom1
XJ40 ( XJ81 )
Jul 2, 2013 11:16 AM
Scubbs
XJ40 ( XJ81 )
Sep 27, 2010 07:11 PM
