XJ40 ( XJ81 ) 1986 - 1994
Help Finding Brake Booster Adapter (to fill it)
Old May 16, 2019 | 09:57 AM
jgause0000's Avatar
Default Help Finding Brake Booster Adapter (to fill it)
I need an adapter to add mineral oil to the brake booster reservoir - in the past I had & used a Castrol mineral oil bottle w/ plastic tube & adapter that was inserted into the reservoir and twisted to lock it in. The bottle was squeezed to force the oil in. I need the adaptor or just a bottle of oil w/ the adapter attached. I've only found very expensive options on-line. Any help will be appreciated.
Old May 16, 2019 | 10:41 AM
Welcome to the forums jgause0000,
I've concluded from the question that you have an XJ40 (XJ6 1986-1994) and moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Old May 16, 2019 | 09:37 PM
Don B's Avatar
Hi jgause0000,
Welcome to the Jaguar Forums! It's great to have you with us.
A couple of possible solutions come to mind. One is that if you replace the oil in your differential (something you should do if it hasn't been done in a while), and if you use a high-quality product like Lucas gear oil, you can clean and save one bottle and tip specifically for use with HSMO:
Another solution might be a syringe with a tube small enough to fit into the opening of the HSMO reservoir opening. There are a lot of options on eBay if you search "syringe with tube."
The ones I keep in my shop for multiple uses are a little more expensive but they are of very nice quality and easily cleaned and reused long-term. Here's a photo and sample eBay listing:
https://www.ebay.com/itm/Bstean-100m...IAAOSwB9FbyKOO
Cheers,
Don
Old Jun 25, 2019 | 02:20 PM
pixiesjag's Avatar
I ordered the Bstean on ebay that don posted and worked great filling my hsmo reservoir just take you time it is a slow fill...
mark1210
Nov 1, 2017 11:41 PM
dweidmann
Aug 28, 2015 05:30 PM
