XJ40 ( XJ81 ) 1986 - 1994
High/low beam relay 1994 xj40
Old Dec 27, 2012 | 09:27 AM
Astroman's Avatar
Default High/low beam relay 1994 xj40
Hi all, I'm new to this forum so I hope there's someone who's got the answer to my problem. I have no high beam on the car. All else works fine but but no flasher or high beams. I've tested every conceivable circuit I can find and all seems ok. Except for the high/low beam relay. Where is it? The modules behind the lights are ok too. So, too summarise
Where is this relay located?
Thanks a lot for any info regarding this problem.
Old Dec 27, 2012 | 02:07 PM
xjrguy's Avatar
There is no high/low beam relay on your car. The beams are controlled by the respective lighting module on each corner. The flash switch at the turn signal sends an input to the lighting switch/module in the pod, which in turn sends a signal to the lighting modules to turn on the high beams.
Cheers,
Old Dec 28, 2012 | 03:39 AM
Astroman's Avatar
Hi ,thanks for your response. I've changed the modules and the problem persists. Could it be the lighting logic unit. I have literally tested everything apart from this.
Old Dec 28, 2012 | 08:04 AM
MidwestJag's Avatar
Astro:
What about the high/low switch itself? Couldn't that also be the point of failure?
Scott
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
sedonajag
Oct 8, 2015 07:38 PM
gunlocators
Sep 30, 2015 08:05 AM
