XJ40 ( XJ81 ) 1986 - 1994
How to do a repair of rubber "boot" around gas tank filler neck?
Old Nov 27, 2023 | 03:01 AM
JensenHealey's Avatar
Default How to do a repair of rubber "boot" around gas tank filler neck?
My 1994 Xj6 that I use as a regular driver has a problem with a split in the rubber boot that surrounds and seals around the gas tank filler neck. Mine has a split in the boot and I am 100% sure these are no longer available. With a split in this rubber boot I am sure I am getting water down in the boot when it rains. Anyone have any tips for how to patch it up?
Old Nov 28, 2023 | 05:49 AM
jerry_hoback's Avatar
Ive been considering contact cement and a trim-to-fit chunk of bicycle tire tube for mine. Too cold out there right now though....
Old Dec 7, 2023 | 10:08 AM
Noah's Avatar
I used Permatex black rubber sealant 80338 to repair a split in mine and it worked. You're right that new ones are NLA.
Old Dec 7, 2023 | 09:12 PM
Did you use any special prep to clean the rubber?
Old Dec 8, 2023 | 04:21 PM
Noah's Avatar
Nothing special, I think I did a gentle clean with soap and water to remove dirt and dust and let it dry well. Then applied the cement where there were tears/splits on both sides of the tear.
Old Dec 9, 2023 | 08:40 AM
Sounds safe. I had a used one that I replaced the original one with, but this one seems to have burst as well. Thanks.
DeusExMaxima
E type ( XK-E )
Jul 30, 2022 02:53 AM
HIJaged
118
Nov 3, 2016 08:50 PM
MIFoodie
Nov 3, 2015 08:57 PM
curtbrown
XK120 XK140 XK150
Jul 27, 2014 11:26 AM
spielnicht
Sep 6, 2012 07:59 AM
