XJ40 ( XJ81 ) 1986 - 1994
HVAC blows cold air from the floor vents.
Old Mar 1, 2013 | 09:43 PM
Jeh's Avatar
Jeh
Default HVAC blows cold air from the floor vents.
After replacing my radiator I've noticed that though I am getting hot air from the dash vents and defrost I am getting cold air from the floor vents.
I have tried cycling all the controls and everything appears to be working. Ive looked at a component diagram from Mitchell thinking there is a stuck blend door motor of some kind but I am not seeing anything as to how it could blow hot through the upper and cold through the floor.
I have searched for this issue but haven't found anything significant.
Thoughts?
Old Mar 1, 2013 | 10:04 PM
MidwestJag's Avatar
Jeh:
Sticky blend flaps seem to be a common fault. Same thing happened on my '94 going into the fall last year, and after some research I decided to start with basics. I undid the passenger knee bolster to gain access to the HVAC box and hit it hard a few times with the butt of a screwdriver. Blend flaps let go and now everything works perfectly! I'd try that first.
Scott
Old Mar 2, 2013 | 12:08 AM
Jeh's Avatar
Jeh
That's kind of what I was thinking. I was too busy trying to fix the door handle to feel like tearing into it more.
02jagstype
23
Oct 23, 2022 07:03 PM
tonyforman
Sep 10, 2015 07:23 PM
OkieTim
Sep 8, 2015 04:48 PM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
