XJ40 ( XJ81 ) 1986 - 1994
Hydropneumatic leveling SLS :Electrical issue
Old Mar 19, 2016 | 12:46 PM
user 797820802834's Avatar
Banned
Question Hydropneumatic leveling SLS :Electrical issue
Hi all
Sorry for the title: this is not HYDROPNEUMATIC but hydraulic
I am taking control over a recently bought XJ40 1989 Daimler.
The first priority issue is to make the SLS system working.
The fuse located into the right side panel on place A1 (a 2 amp fuse) is fusing after some minutes of ride
When not fused, the rear suspension is working as expected
I tried to read as much as possible on this topic , here on the forum and other related ressources; but not able to understand was is the cause of such electrical problem.
I add that the cruise control unit is erratic; some times it can be engaged, but not possible to have it working again after a pression on the brake pedal.
I would greatly appreciate some directions on where to search for faults (the wiring diagrams I was able to look at did not help so far).
Thanks in advance.
Old Mar 21, 2016 | 07:08 PM
motorcarman's Avatar
The Jaguar Publication S73_XJ40 Power System Hydraulic has all the info you require. I uploaded it to the large file area for others to download.
It is 'out there' on the internet.
bob
gyoungwolf
Oct 5, 2020 07:33 PM
grahamuk33
Mar 24, 2016 07:36 AM
wazdude
Mar 19, 2016 12:26 PM
hawaiianjag
Mar 17, 2016 05:58 PM
Jaguar Forums Editor
Jaguar Press release
Mar 17, 2016 12:48 PM
