XJ40 ( XJ81 ) 1986 - 1994
identical engine swap 90 xj6
Old May 27, 2010 | 05:25 AM
granpapafred's Avatar
Default identical engine swap 90 xj6
bought a 70,000 mile engine complete with wiring accessories fuel sys, manifolds etc through a/c comp. what is correct procedure, don't have a car lift, but have jack stands, air tools, and a good engine lift. the more details you give the fewer mistakes I will make. My basic questions are, with the radiator out, fan off, exhaust loose intake loose, do I pull the engine only or eng and trans, will it come out and go in dressed?
Fred
Old May 27, 2010 | 11:02 AM
Fraser Mitchell's Avatar
Sorry to tell you you are on the wrong forum. As a 1990 car, your's is an XJ40 model so you need to post there. This forum covers the original XJ from 1968 to 1986 (67-87 in the US).
Old May 27, 2010 | 03:14 PM
Doug's Avatar
Fred
The correct procedure would probably total 100 individual steps or more.
Maybe if you narrow down your question a bit someone can offer some help. Otherwise, use whatever procedure is in the shop manual
Old May 27, 2010 | 04:52 PM
Cadillac's Avatar
Surprisingly Jaguar kept making these Series III models until '92 .Still, I think he has got an XJ40 that's why I am moving it off to the proper forum
Old May 28, 2010 | 08:16 PM
Lumppy47's Avatar
Default engine swap
You will have to elivate the vehicle so that you can get under it (make sure its well supported).Leave the transmition in the vehicle(you will have to support the trany,just get a long 2 X 4 and using the holes in the front jack mounts bolt the 2 x 4 across the tranny and it will hold it in position) Then take the inspection cover off the bell housing manually rotate the flywheel(flex plate) and remove the bolts from the torque converter. Remove hood radiator(be extra careful wit the transmition lines)and then use your lift (good idea to have a balancer attachment) then its just like pulling any motor. Ita a good idea if you get a haynes or clifford manual.good luck Lumppy
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
