XJ40 ( XJ81 ) 1986 - 1994
Ignition ON signal
Old Jan 10, 2022 | 06:06 AM
100bars's Avatar
Default Ignition ON signal
I have installed new LED quad lights on my XJ40 1994 which include LED Halos. The lights have a single wire to connect for DRL (daytime Running light) and one single wire for the indicators.
I have connected the indicator wire and it works fine
The other for DRL I wish to pick up a power supply (preferable in the engine near the front) which operates when the car is ignition ON but headlights are OFF.
Can anyone recommend a suitable supply and suggest the correct wire? (photo would be appreciated)
Cheers John
Old Jan 10, 2022 | 09:44 PM
NTL1991's Avatar
There are plenty of spots to get an ignition-switched voltage source, but I can't think of a single one with your requirement of being live only when the headlights are OFF.
Old Jan 11, 2022 | 03:18 AM
100bars's Avatar
thank you for your reply
I might have phrased that wrong I mean live when headlights are both OFF & ON
Old Jan 11, 2022 | 11:09 AM
Lawrence's Avatar
DRL's on Canadian models are switched on with the ignition so illuminated when cranking FWIW.
Larry
Old Jan 11, 2022 | 11:33 AM
NTL1991's Avatar
Larry
Larry, do you know if DRLs on Canadian cars are a function of the bulb failure modules, the central processor, or something else? No experience with them here in the states.
If so, it seems like a simple swap with the correct BFM would give you a very clean install of aftermarket DRLs without having to tap into all kinds of wires
Old Jan 11, 2022 | 12:24 PM
Lawrence's Avatar
I believe they are linked to the modules Nick - but it's been a while since I had a look at them - might be an idea to check the catalog for different part numbers for Canada?
Larry
ps I probably have a spare set in my stash.
gmsclassics
Jan 27, 2018 09:10 AM
patpin
Aug 26, 2016 10:16 AM
Sarc
Oct 30, 2013 07:07 AM
Kneedeeprough
Dec 29, 2011 08:09 AM
MTZGR777
Apr 11, 2010 01:47 AM
