XJ40 ( XJ81 ) 1986 - 1994
inertia switch - Fuel Line 12
Old Oct 5, 2011 | 11:50 AM
dann59's Avatar
Default inertia switch - Fuel Line 12
would a defective switch cause the check engine light to stay on?
Old Oct 6, 2011 | 03:54 AM
Cadillac's Avatar
It should not as far as I know ,a faulty switch is like a firewall to your computer so it hinders your engine starting up .
Press VCM button and if it also throws a code please shoot it here , our experts will gladly help you out
Old Oct 6, 2011 | 07:30 AM
dann59's Avatar
thank you regentv12 ,i'll try that and let you know. dan
Old Oct 6, 2011 | 05:28 PM
dann59's Avatar
regent v 12 i checked the vcm code and it said fuel 12. would you have any clue as to what that means? thank you, dan
Old Oct 7, 2011 | 04:22 AM
Cadillac's Avatar
That's good at least it popped out a code . I will check out my owners manual if it states anything about it , I will let you know .I am not expert but glad I could guide you right way . BTW , I am editing your title so that it will attract more attention
Old Oct 7, 2011 | 05:08 AM
Cadillac's Avatar
Hey, quick update
I looked at the manual and saw a topic on inertia switch . I am uploading an image so that you can see a resetting procedure for it .
I found check engine code that corresponds 12 and here is why you get it , it is from MAF according to what I found
Hopefully these will work for you
Attached Thumbnails inertia switch - Fuel Line 12-image420.jpg   inertia switch - Fuel Line 12-image421.jpg
Old Oct 7, 2011 | 01:44 PM
MidwestJag's Avatar
Oh Danny boy:
You should get a copy of the Haynes manual for this car. It is by no means the Bible, but can be helpful in troubleshooting. Page 6-7 outlines how to go about checking the MAF sensor. It may need to be replaced.
The inertia switch, if tripped, would completely immobile your car. I don't think it's related.
Cheers,
Scott
Aus V8S
Nov 13, 2015 11:01 AM
explorer364
Sep 11, 2015 05:44 PM
1964Daimler
Sep 9, 2015 04:50 PM
1964Daimler
Sep 9, 2015 11:28 AM
Bones
Sep 8, 2015 08:34 PM
