XJ40 ( XJ81 ) 1986 - 1994
Jaguar xj40 1991
Old Dec 9, 2017 | 05:20 AM
Drazen Markovic's Avatar
Default Jaguar xj40 1991
i fell in love into jaguar and in this type,when i sell my current car i will probably buy this one,what should i look to inspect on this car,i sow 3.2 straight 6 thats fairly cheap in my country,I did search net and found its roting much under doors and such places,but what else?
Old Dec 9, 2017 | 09:20 AM
Don B's Avatar
Hello Drazen,
Welcome to the Jaguar Forums! It's great to have you with us.
You can find a lot of information about the XJ40 in the Jag-Lovers eBook, which you can visit at the link below. You may need to join the Jag-Lovers forum in order to access the information, but it's free:
Jag-Lovers XJ40 eBook
Here's a list of some of the issues to look for on an XJ40. Hopefully other members will offer additional ideas:
Engine starts easily, idles smoothly and steadily at 750 rpm or lower, revs easily
All gauges and lights in the instrument cluster operate correctly
Transmission shifts smoothly
No whine or grinding from rear end of the car
Knocking sounds from any part of the suspension (perished shock bushings or suspension bushings)
Oil leak from cam cover gasket leaking oil onto the distributor and/or exhaust manifold (cam/valve cover gasket)
Play in steering (front wheel bearings, steering rack, worn suspension bushings)
Sagging headliner
Climate control system blows strong on both heat and cool settings and fans run at all three speeds
Rust, especially along the windshield and backlight seals and wheel arches, underbody
Signs that the car has been neglected (for example, the air filter, fluid levels and condition, cracked tires)
Any previous owner modifications (non-original wiring in the engine bay, etc.)
Check the Vehicle Condition Monitor for any stored Diagnostic Trouble Codes (DTCs). To do so:
1. Turn the key to position II (ON), but do not start the engine.
2. Press and release the VCM button on the trip computer to the right of the steering wheel.
3. Watch the small display window below the speedometer where the mileage reading/odometer normally appears. DTCs appear in the form of "FF" or "Fuel Fault" plus a two-digit number, such as "FF89," or "Fuel Fault 22." If any message appears, write it down exactly and post it here and we'll help.
Good luck, and please keep us informed!
Cheers,
Don
Old Dec 13, 2017 | 02:43 PM
Jaguar XJ | INDEX OGLASI
this is the one im probably buy,guy sales one fully functional and one whole for parts if everything is ok i will buy both for 1500euro
what u guys think?
Old Dec 14, 2017 | 04:34 AM
Welcome to the forum Drazen,
The problem with XJ40's in Northern Europe is RUST. Here is the bonnet of my XJ40 twenty years ago when it was eight years old:
Jaguar xj40 1991-01a-bonnet-front.jpg Jaguar xj40 1991-02a-bonnet-ns-edge.jpg
It had to be replaced as did the boot lid.
If body parts are rotted, finding replacements will be difficult so you need to be certain they are repairable.
Hettle
Oct 9, 2017 06:32 PM
Petrol Caps
Oct 19, 2014 09:44 PM
XJDash
XJ40 ( XJ81 )
Oct 3, 2010 07:27 AM
kreal
Sep 25, 2008 07:20 AM
wingnut
XJ40 ( XJ81 )
Jul 19, 2007 12:52 PM
