XJ40 ( XJ81 ) 1986 - 1994
leaking sun roof
Old Aug 29, 2011 | 11:08 AM
Doug's Avatar
Are the drain tubes clear and/or correctly attached?
Old Aug 30, 2011 | 08:15 PM
AJR's Avatar
AJR
My right front drain clogged and caused a water leak into the car which ruined my headliner, then dripped down and ruined the wood pannel of my center consol & destroyed my passenger front seat bottom. On my 89, the front drains are vinly / rubber tubing that run down the side windshield pillers and dump out on the bottom rear portion of the front fender wells. If they are clogged, you can try to carefully rheem the drain tubes out from the top or you can take off the front fender wells and clean out the drain tubes from the bottom (or both).
Old Aug 30, 2011 | 11:47 PM
Jagfix38's Avatar
Just make sure you clean out the duck bill drain in the engine bay on the firewall... about half way along in line with the cam cover. This clogs up and causes water to back up below the windshield in the firewall cavity which is the usual cause of water in the foot wells.. A lot of people usually suspect the sunroof but this is not normally the culprit.
Old Aug 31, 2011 | 07:54 PM
dbrojr's Avatar
mine was a combination of the duck bill plugged and small rust holes under cowl below windshield....no water inside now....
Sambo21
Nov 19, 2015 03:55 PM
Papelione
Sep 21, 2015 06:13 PM
picard
Sep 19, 2015 08:13 PM
Steve10
Sep 9, 2015 07:54 PM
Jay48
Sep 7, 2015 09:30 PM
