XJ40 ( XJ81 ) 1986 - 1994
Need driagram of vacuum lines heater area
Old Nov 29, 2010 | 02:56 PM
91xj6owner's Avatar
Smile Need driagram of vacuum lines heater area
Does anyone have a driagram showing in color what vacuum lines go where? Specifically the ones dealing with heat/ac such as the ones coming off the heatercore/evaporator box UNDER THE DASHBOARD.
This is on a 1991 xj6 vdp late model thanks
Old Dec 16, 2010 | 03:41 PM
xjrguy's Avatar
I just ran across this post. Give me a little time, I'm sure I have what you are needing. Might take me a while to dig it up.
Stand by.....
Old Dec 16, 2010 | 08:07 PM
xjrguy's Avatar
See if this is what you need.
Good luck!
File Type: pdf
Old Dec 22, 2010 | 12:27 PM
carlosz's Avatar
when I got my 89 it had been butchered in more ways than one including those vaccum lines, unfurtunately the butcher had removed many of the solenoids.
I found a donor at the local junkyard and carefully removed as much as i could of the line with out disconnecting from the solenoids, i cut the connectors as well.
the transplant to my car was much easier.
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
Bcrary3
Feb 21, 2023 04:29 AM
explorer364
Sep 11, 2015 05:44 PM
Saturbo
Sep 8, 2015 07:35 PM
